View all of the ACE protocol entries associated with an ACL.
- Select Advanced Filters (ACE/ACLs).
- Select the ACL tab.
- Select the appropriate ACL.
- Select Proto.
Protocol Field Descriptions
Use the data in the following table to use the Protocol tab.
Name |
Description |
AclId |
Specifies the ACL ID. |
AceId |
Specifies the ACE ID. |
SrcPort |
Specifies the port number or port list to match. |
SrcPortOper |
Specifies the operator for the ACE protocol source port. |
SrcPortOperMaskRange |
The value is displayed in hexadecimal format when SrcPortOper is set to mask. When SrcPortOper is set to range, this field is used as the high range value. in this case, the value is displayed in decimal format. When SrcPortOper is set to eq, this field is set to 0. |
DstPort |
Specifies port number or port list to match. |
DstPortOper |
Specifies the operator for the ACE protocol destination port. |
DstPortOperMaskRange |
The value is displayed in hexadecimal format when DstPortOper is set to mask. When DstPortOper is set to range, this field is used as the high range value. In this case, the value is displayed in decimal format. When SrcPortOper is set to eq, this field is set to 0. |
IcmpMsgTypeList |
Specifies one or a list of ICMP messages to match. The valid range is 0–255 (reserved). |
IcmpMsgTypeOper |
Specifies the operator for the ACE protocol ICMP message types. |
TcpFlagsList |
Specifies one or a list of TCP flags to match. The valid range is 0–63. |
TcpFlagsOper |
Specifies the operator for the ACE protocol TCP flags. |
TcpFlagsOperMask |
Displays the mask value in hexadecimal format when TcpFlagsOper is set to mask. When TcpFlagsOper is set to eq, this field displays 0x0. |
